Test new Avatar
Does it move
Is it small enough ?
Channel Hopper said:
Does it move
This size would probably fit better. :)
Can you reduce it to the 20K for Satdudez ?
Im known under another name on that site, but dont have any software able to play with animated gifs
This is the 20k size, but it loses something in the translation. :)
Yes I tried
Oh well, I might use it elsewhere
Working with Flash, and bribing the wife to help me, gives me these two at 50k and 20k max
Seems the Gif works site adds something to the images (especially moving ones), and so sacrificing quality to keep the space is the only option
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
The 20k version looks ok to me CH. I see you turned the bear round from the original. Mirror image?
Just a transformation, though I did remove about ten frames and reduce the colours of the original to bring the whole thing into the magic 20k size
It was something I spotted on B3ta a while ago and was wondering when it might come in useful, hopefully the adjustments mean Im off the plagurising list.
Yes, even the smaller one looks good. :)
Any idea how to get the URL of the smaller image ? i would like to add it to my profile at Satdudez, but they dont allow direct from PC avatars
Thanks - now up and running on both sites
