tevii s480 minefiled after coming from dreambox
loady
main rig: Intel i7 3.8Ghz, 8GB ram, 128Gb SSD, GTX 570 GPU..all water cooled.
HTPC setup: Intel G840 2.8, 4 GB ram, 60GB SSD, HD6570 GPU, Tevii S480 dual tuner dvb s2 HD card
surrey
Been using dreamboxes for some years (plenty of support and help setting up) and i decided to build a HTPC system, its a well specced system, intel g840 dual core @ 2.80, 4gb of ddr3 ram and an radeon HD6570 graphic card, im running XBMC and this system plays EVERYTHING flawlessly. So i wanted to intergrate my cs into the HTPC system, i have managed to get FTA running but there is an awfull framskip issue every 2 seconds, i am using dvb viewer pro to try out the card but i am reluctant to pay for it unless it does the job..it was a nightmare just finding out how to use/get HADU up and running and have been blindly following someones advice on what to do, although i have picture its is crap...is it the hardware ? is it using my GPU to its full potential ? i really need a good starting point to get the best out of this, any help greatly appreciated.
Could try Oscam for Windows as your cardserver. What are you using to read your smartcard? (presumably for other channels beside FTA ones).
Can't help with the HTPC side, as I only use the PC with DVBViewer Pro and Oscam/ACamd for channel viewing.
loady
surrey
The HTPC is essentially a pc, i am running windows 7 on it and i am just trying to get the card going well with dvbviewer or anything else before i look to intergrate it into XBMC.
hmmm..card server ? i was previously sharing my brothers card on the dreambox, i intend to do the same with this so i dont physically have something reading a card, i have a plugin installed in dvbviewer pro called HADU, i assume thats a card server ?...the stuttering is with FTA channels so if thats sorted i am sure it will be fine for the encrypted channels when i get round to getting them going
