Thor 7 0.8W Ka feeds
Here's a data carrier in Ka Band B, presumably 0.8/1W (that's what my dish is pointed at).
20016V 44991 3/4 ACM feed.
Could be a satellite other than the usual ones there, but I don't know of any others +/- a degree around this spot (?)
Archive-8
Can you still find the feed please @Llew as I am struggling to find it :-(
It's always very weak with my Inverto Ka LNBF Chris. The peak's still there at present, but rain has killed any hope of a lock.
When it stops, I'll try with my Hughes LNB, - my modded Inverto has been 'tuned' for Band C working.
Anonymous_1
Thanks @Llew
Here is my scan with SL3,
There more active Txp I think
I will have alook carefully with another LNB ASAP
Much better with the Hughes. There's another feed at 20170V, but that may be out of your Inverto's range Chris.
Anonymous_1
I was right, there more active Txp: it's time to open a dedicated or move them to Ka band :)
now with my KA band B LNB
Anonymous_1
The best I can do for tonight... different beams I think :mellow:
Archive-8
[SATTYPE]
1=3592
2=Thor 7 KA-Band
3=5
4=18050
5=0
6=0
[DVB]
0=5
1=19732,H,44990,34,132,|-64 dBm, 3.9 dB
2=20017,H,44990,34,132,|-57 dBm, 11.9 dB
3=20017,V,44990,34,148,|-63 dBm, 6.1 dB
4=20170,V,44990,34,132,|-64 dBm, 8.6 dB
5=20170,H,44990,34,148,|-61 dBm, 12.3 dB
Looks like I still have a problem with ghost transponders. :-( but I think I have found 1.0W Ka
Quite a variation in strength with these carriers, 0.1dB to 16db with me. This is using my Hughes LNB on a Triax TD88.
it happen on ku band 12207h also maybe not stable also in ka band
Thor 7 Ka Beacon?
20130 R/L
May be off absolute frequency, I'm using the Hughes with wandering LOF :eek:
A couple gone for me today, 19826R and 20109R. As is the way with feeds of course.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Thor7Ka.png and here's my submission ..
obviously these data transponders are circular polarised ...and my Hughes is currently set physically in Linear mode ...thus repeats in both scans ...though not identical sig levels and 3db under what could be acheived ..
rgds
VS
Nice find Feedsat :)
Wide carrier, busy PID throughput.
Archive-8
[SATTYPE]
1=3592
2=Thor 7 KA-Band
3=5
4=18050
5=0
6=0
[DVB]
0=6
1=19733,H,44990,34,148,|-63 dBm, 5.4 dB
2=19733,V,44990,34,132,|-64 dBm, 2.7 dB
3=20018,V,44990,34,132,|-61 dBm, 8.2 dB
4=20018,H,44990,34,148,|-55 dBm, 12.4 dB
5=20171,V,44990,34,132,|-62 dBm, 8.9 dB
6=20171,H,44990,34,132,|-59 dBm, 12.2 dB
