thor sat
scorpio92
technomate
united kingdom
hi there
i heard that i can get thor sat in my thechnomate by use of a software
does anyone know which software this is
Mickha
North West
Thor is a satellite at 1 West, well 0.8 & 1W, to be accurate, I think what you're trying to get is the Digi TV package on the 1W satellite.
The software you are referring to is called a Patch, I think that they are now produced by Magic, they were formerly created by Darkman.
If you do a google search for Technomate patches, you should quickly find them.
Try this link to see the Nagravision 2 channels you can open, but Digi TV will be upgrading to Nagra 3 encryption soon so make the most of them:
_http://www.lyngsat.com/packages/digi.html
scorpio92
technomate
united kingdom
thanks alot man
