Titanium advice
Onthehill
Shropshire, Uk
Any advice I might need for programming Titanium.
Using technomate 5500DAPCI, XCAM 1.04 and blue Titanium 1.06.
What files should i download to get the best viewing possibilities on 19.2 E.
Tried yesterday but could only view tequilla 5 - 7
Can i get more?
Thanks in advance
Grayarea
Visit site
Newport, Co Mayo
There is an update for the Xcam that opens what you want, you will find it at toecutters. The latest titanium file by MOD will also open these, that is at toes as well.
Grayarea.
Onthehill
Shropshire, Uk
Thanks Greyarea.
Downloaded the file you mentioned yesterday and have programmed the Card several times. Card definitely opens only Tequilla 5-7, the only other channel which had any signs of life was Tequilla X showing a short X graphic, before reverting to "channel scrambled".
Maybe i need to update the cam, any ideas how to do this?
Thanks again
Grayarea
Visit site
Newport, Co Mayo
I don't have one, but I understand you can use funcard 5 or 6 or an interface card which you should be able to get from the shop you got the cam from.
Grayarea
