Titanium card -> Aston 1,05
Kenneth_P
Visit site
Hi all good folks
Hope someone can help me, I'm using a titanium card on an Aston 1,05 for decoding Sky Italia, and it works, but all the time i get the "popup window" on my screen/tv (Aston crypt V1,05 No right to watch this program) but it still encode the channal, i just have to press the "exit" button on my remote to get rid of the "window"
Anybody knows what to do?
Best regards
Kenneth_P
This is like the old problem we used to have with the Freecam, not sure if there is anything you can do.
Just had a look around and it may be that downgrading the Titanium operating system to 1.03 and then re-flashing the card may do the trick, seems to work for some people. :)
Kenneth_P
Visit site
Thanks Rolfw, will try that as soon as I get home this evening.
Nope didn't work, instead I ended up with a "****ed up" titanium card, totally dead now :-(
Any way to restore such a card ?
Best regards
Kenneth_P
Which titanium progger version did you use Kenneth_P?
Kenneth_P
Visit site
I used Titanium OS updater 2 , to downgrade to OS 1,03, and then Titanium progger V 1.10.0 to upgrade the card, but it would not upgrade, just wrote something like: could not upgrade card, or failure writing to card. Don't know whats wrong, maybe I've destroyed the card, don't know :-(
By the way, It's a white titanium card, don't know if that matters, if it's white or blue card ?
Best regards
Kenneth_P
You may need to use a version like 1.08.0 or earlier to program the card with 1.03, I think that was how I did it. :)
Kenneth_P
Visit site
I've downloaded Titanium progger 1,05. Put my card in the programmer and press, Restore OS in the tool meny, and this is all that happens.
ATR : No ATR !
unsupported Titanium OS found.
resetting card...
-> sending TRAPCODE...
And there it just hangs. I know the programmer works cause I've just programmed a MII card with the same programmer, and it works just fine.
Best regards
Kenneth_P
Just looked back at you post and see that you tried to upgrade after downgrading, was that because the card wouldn't program with the earlier version?
