Titanium Card
talwell
Is the titanium card locked down or is it able to be read no matter what is loaded on it? Can dealers lock it down so that it cannot be read by users?
coconut
Window XP
4 x Receiver,
2.4M x1 0.6M x8, 0.9M x1, 1.2M x1
HKG
I do have the same question, can someone ask?????
thanks
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
I know that some programming software (e.g. multiprog by TJ) does have a 'lock' button but I've never used it. I suppose you are concerned that unscrupulous dealers will 'lock' the card so they can charge you to update it. I don't think any of the suppliers most of us use would do that because the whole point of the card would be lost.
coconut
Window XP
4 x Receiver,
HKG
I do see a TC come with ROM10 xxx but after i5t put in the receiver then it auto update to higher version, so just wonder what happen inside the card, most of the files say it is autoroll and will be change key when it have update, if the data inside the TC can be retrieve, the key can be found and I can use it for my ProDVB.
on the TC programming software, I only see the Load HEX and Load EEP but NO read card, just wonder should it have a button with "read card" ?????
There is a file already available for the PC card Coconut, look for MACH1 on Toecutters in the file section.
peppey
obviously it's a Titanium card,I dont know if you erase card first and put in phoenix mode with TJ's multiprog 1.50 software?
agar
Could anybody tell me who is producer of the TitaniumCards ?
They are in Germany Agar, don't know their details though, although a few well targetted searches in Google would probably yield the information.
