bureaucrazy
- Feb 16, 2012
- Age
- 55
- planning future installation of satellite TV
- east of england
Hello,
There is 2XCF100 coax cable to several rooms in my house. In some of the rooms the cable comes up from under the floor but in others, it runs down the wall. The quadraplex outlets I have seen so far are bottom entry only(ooh err!). The only way the cables will go in is if you put the outet upside down, but then all the labels are also upside down.
Is there any outlet that has top entry? Is there any outlet with no labels?
Does it matter which manufacturer's outlet I choose (e.g.frequencies that signals are split may differ) or do I need the same make of loft box? I am considering Wolsey or Labgear.
Other than that is there any advice on how I can bend the cables round to make them upside down because they are not all that flexible.
