TPS Code work for minutes only
felmir
Starsat SR-X1900D
starsat SR-X7000D
LEB
Hello Every body
lately on any new version when i turn the received on after a couple of seconds it will open the TFS chanel than after 2 minutes it will becom scanbled aanybody is facing this probelm otherwise olsat and other chanels are working normaly.
also why we cant find new software those days every 2 to 3 weeks till we find a new software
Thats the way TPS behaves on many receivers these days. Theres not much you can do about it.
felmir
Starsat SR-X1900D
starsat SR-X7000D
LEB
in this case is there any specific receivers will work with TPS what do you recomend?
Mickha
North West
There is a new card that's supposed to open TPS, the Vista card, but TPS will be closing down shortly so is the expense really worth the few channels available?
felmir
Starsat SR-X1900D
starsat SR-X7000D
LEB
thanks michka for your reply i just forget about TPS and went to buy a new receiver today from starsat and i was a little bit confused between srx4000D super wich have a good reputation and a new model from star sat srx7000D do you have any idea about it did you ever tried the 7000D ?which one do you recomend ?i am confused about both
felmir
Starsat SR-X1900D
starsat SR-X7000D
LEB
it seems all new starsat series have the same menu i tried the 7000D ,4200D and 4000D all are the same
