doggy
about one week ago i lost all my tps channels although im still getting multivision. is anyone else getting tps?
thanks
thanks
doggy said:what are keys? and how do i update them?
thanks guys
hi petchletch, tps & multi are still o.k. you might not be following the instructions on the keys text file, if you do not get it correct the mr will not save them. rob43petchletch said:Hi
MR are the Matrix Reloaded files. I lost my TPS 2 weeks ago too. I've upgraded my Matrix CAM to v1.081 but still no TPS. Do you have it back on yet?
doggy said:what have i done to get a "well done"? have i done something wrong? sorry razor im not sure what you mean, hope im not in trouble
hi petchletch, sorry i should have said. you will get the text files at www.phillsatfiles.com or at toes. mach1 usually has a text file along with the mr files. otherwise look for the updated mr key files. rob43petchletch said:Hi rob43
I've checked my mr1.081 zip file - not actually sure where i got it from now but there was no keys text file in the zip only .upd , I'll find another site and recheck - thanks will keep you posted
hi petchletch. dont know what you mean by "*.key files". if you think you cant post it, pm me. rob43petchletch said:Hi Rob43
Thanks for that (phillstafiles is down currently, but I will check later) - I did mean to ask - how do *.key files get used but maybe that's for one of the other forums - I just can't seem to find it.
