Wellcome friends i want ur help i have a new receiver Truman gold and i want to update its software so i want the sites where i can download the software.
This is a self help forum and if you had searched for your stb you would have found this thread although I am not recommending that you flash your receiver but it is amazing what can be done
One point to note Alaa945 - if the flash goes wrong you will probably ruin your receiver. There are regular appeals for help on this forum from folks with broken receivers.......
Good luck if you go ahead, but bear the warning in mind.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
