Advice Needed Turkmenälem/monacosat at 52.0°e
Gladstones
Zone 2 Fixed at Astra 2
Gibertini XP 75 cm fixed at 30 west
Gibertini XP 1 meter motorised 53e to 27.5w
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Hi octagon sx88+ se is missing TurkmenÄlem/MonacoSat at 52.0°E
so I added it what is the lnb freq will be
9750/10600
Or
5150
I added a strongest tp
Any suggestions thank you
I updated firmware
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
With your dish and LNB at your location, ALL Ku band transponders on ALL satellites require the "LNB freq(uency)" to be set to 9750/10600
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
I checked the list some sat got 5150 ?
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Is at the end of list can I not squeeze between
49E and 52.5E
Or it’s make no difference
nelson_b
Contributor
Unfortunately that seems to be the default setting on the SX88 family for most of the satellites! As @nelson_b said, it is for C Band, not Ku Band, LNBs - so change the setting on all the sats to 9750/10600.
49E and 52.5E
The arc difference between 52E and 52.5E makes no difference unless you have a much, much bigger dish! Anyway if you scan what you think is 52.5E you will get a large number of channels which are actually on 52E as that sat has a much stronger signal footprint than 52.5E in the UK (check lyngsat, flysat etc. for lists of which channels are on which satellite).
You wont get anything off Al Yah 1 - theres been nothing on the European beam for months.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
So no need to add 52 e and use 52.5 instead
Can I delete newly added 52 e
No I would not delete 52E, but I would delete 52.5E for the reason just stated by @Analoguesat (i.e. there's effectively "nothing there" that can be received in the UK)- if for no other reason than to avoid "getting confused" in the future when editing/adding/deleting channels on 52E!:rolleyes:
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Ok thank you I keep 52 and del 52.5
