Twin LNB a motor and 2 receivers
marcaaron20
Dreaming Satellites
Dreambox 8000 HD,
80cm Orbital Satellite Dish
Motorized
LNB with 2 outputs, 2nd output leading to upstairs and using Dreambox 500S.
Pioneer VSX-1018AH-K Amp/Receiver,
Stockton-on-Tees, Cleveland
later on today, I am getting my motorised satellite system installed, this is the setup I'm planning
80cm Orbital Dish with a Twin LNB (0.2db) on a Fortec Star DiSEqC 1.2 USALS motor, motor will be connected to a Dreambox DM 500 S in my downstairs room and the 2nd connection from the LNB to a Technomate TM1000D which will be in my upstairs bedroom
will this work??
Of course. Only slight inconvenience is that both receivers have to share the same satellite position that the Dreambox is currently fixed on.
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Hi,Not sure if the DM500S has an rf output connector, but this would be useful as then you could use a remote extender to change satellites from upstairs.
