Two Dishes with two dbox1s
jonh877
Nokia Dbox1 and 60mm dish
Manchester
I have two dishes pointing at different satellites. The dish cables are combined via a DiSEqC combiner into one cable and then split back into two cables to feed two dbox1s ( in separate rooms ) with the intention of being able to view all channels from both satellites on either dbox ( not necessarily at the same time - the set-up is more to avoid having to carry equipment back and to ). I tuned the dboxes in to each satellite separately but then only seem able to view one satellite's output. I'm inexperienced and baffled by the DiSEqC technology - I was hoping that 'things' happen by magic. What am I doing wrong? What am I omitting to do? Thanks.
When you say the cable is split - how have you split the cable?
jonh877
Manchester
With a splitter unit from eBay.
satelliteman
Twin LNb feeds from each dish feeding two DiSEqC switches required :)
If only one box required at a time, then loop out box1 to box2.
Take the splitter out and throw it in the metal recycling bin. You need individual feeds to each receiver.
