UHD Spain HDR & SDR
Satfaca
Melmac (46N, 14.5E)
Melmac
Two new 4K channels started on 11.382 V, SR 30000. In clear.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
I can receive these HEVC channels but when I look for them in 'NEW' Channels I find nothing on both Dreambox Recivers that
is to say DM 900&DM 920, whilst on my Octagon sF008 no problem. Does this means that the DMs cannot decrypt HEVC channels?
Satfaca
Melmac (46N, 14.5E)
Melmac
The fact is that these channels get recognized as "Data", being marked as "Type 32". Try to change that to "31" in the DreamBoxEdit and see if helps...
antrabe
dreambox7080 dm900 viark droi
spain
I cant play also with nn2 image and dm900 neither viark droi. Are the same channels that i can receive on dtt in Andalucia. nevertheless with my tv lg can play with dtt witouth problem.
its strange because few days ago only one the channels were in test and can be played by both receivers. I have recorded and info about is:
Video: HEVC 3840x2160 50fps [V: hevc main 10 L5.1, yuv420p10le, 3840x2160]
Audio: MPEG Audio 48000Hz stereo 256kbps [A: Spanish [spa] (mp2, 48000 Hz, stereo, 256 kb/s)]
Stevenvc19
3x Edision Primo S2:
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
I can scan those two channels on my Edision MIO+ but none of them give a picture. Only sound... can someone confirm if they have the same problem? Thanks!
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Yes I do on both my Dreamboxes 900&920UHD but not on my Octagon Sf8008 in which case I have both picture and sound.
(N.B.) I substituted type 32 to 31 on dreamBoxEdit but all I got is the sound so far.
EnoSat
enosat.euweb.cz
Slovakia
must write on openpli or openatv for fix OE2.0
MCelliotG
Thessaloniki, Greece
Level 5.1 on HEVC is NOT supported on a very wide range of 4K receivers....
HD51 being one of them...
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Is this hardware related? Or can it be fixed with some sort of firmware upgrade for the decoder?
Good reception here,
New UHD on 30 west working on my Octagon SX88-4K 88cm dish.
MCelliotG
Hardware related, unfortunately. Only via stream on PC/mobile where a software encoder takes over.
4Himdj
1.2 Laminas Dish
Rome
working on ax hd61 too
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Now I got picture on my Edision OS MIO+ 4K
Maybe they adjusted the video codec! Give it another try for those who didn’t get a picture the first time!
MCelliotG
Yes, something has changed, however I still see level 5.1 in the codec info, so something else is going on... how strange. :-doh
Anyway, two screencaps
MCelliotG
OK, now I have discovered what has changed. The initial transmission was HDR/SDR type 32
0x20 HEVC UHD digital television service with HDR and/or a frame rate of 100 Hz, 120 000/1 001 Hz, or 120 Hz, or any combination of HDR and these frame rates.
and many receivers had problems with the frame rate, as most SOCs will support up to 60Mhz.
Now they changed to
0x1F 50/60 Mhz HEVC digital television service
which is compatible in a wider range of commercial 4K receivers.
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Looks like these channels are gone…
anyone else who has noticed this?
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
