damhy
- Jul 24, 2004
- Age
- 42
- Kent
Right guys / girls.
I hope someone has done the Next patch for Technomate 5000 receivers and has also been as disappointed as me. Only because that will make me feel better!!!
Anyway I'm trying to sus out how to get round this irreversible patch and its really annoying me. So I am hoping someone is in the same situation so that they can play around like I am and get it fired up again.
Basically I copied the first few lines from the YE-2000 firmware, plonked it in to the original technomate firmware. Now by using PCLink 02.0i and selecting to upgrade the boot, I can load this firmware in to the receiver. I ws even surprised to reset the thing and find my original Technomate splash screen and have a working remote again.
Yes it fired up and worked fine. So, why am I posting this??? Is it to help you all out to restore the thing??? Nope, its because it failed. Failed??? But why when you have the working remote, working splash screen...
Well the problem is that as soon as I turn off the receiver using the switch at the back (clicking the stand by button is fine). When you turn it back on there is nothing. How weird, it worked 30 seconds earlier, and then its gone when you reboot again.
So maybe I have a blind hope that I can restore my receiver. Maybe it is really possible. Someone must have some idea. Someone must want to experiment.
I think the only tip worth noting is that if it screws up then it would appear you can in most cases, use the up button on the front, flick the switch and it will take a boot load again. Not the main program update since this required some info from the receiver.
Come on guys, its got to be possible, I will never meddle with the receiver again, if i can get it back to original state ;)
BTW I Have the Technomate 5500 CI - Plus (which takes the super firmware).
