Unspported Os - titaniumprog
pegasus30_1
Hello,
Can someone help me: i've a Infinity USB Phoenix and a blue tit card. When I activate the titaniumprog 1.10, it mention no ART - Unsupported Os. I'm I doing something wrong?. The titcard I used was working perfectly untill 2-3 weeks ago when skyitalia disaperead. I know i've to put the card into Os 1.06 and that's all :-)
Thanks for helping me
digimac_uk
Manchester
Hi Pegasus,
check the read me file in the card files that you download, some of them require that you downgrade the card to 1.03 os. The tool for doing this is in titproger 1.10 and it is fairley easy to upgrade back to 1.06. Have a dabble, I don't think you can do much damage to the blue titanium card!!!
Norm
Aberdeen
Channel Master 1.2m motorised, V Box, Technomate TM-5402HD.
Aberdeen, Scotland
Unsupported Titanium OS always seems to come up when you connect the programmer. Go to Tools, erase card - and erase it. Then bring the card back to OS 1.06 (if need be), load your hex and eep files and burn the card.
If the card will not TRAP with 1.10, try the 1.80 version, seems a bit less fussy.
pegasus30_1
It's the first post I put on a forum, but Ur all great !!!
Thx for info
I tried but none of the files works ( to have skyitalia). I went to the site fookfiles.com under seca 2 and wholetthedogs.. Everything black :-(
What receiver and CAM are you using?
Unfortunately, looks like Sky Italia is not now available to anyone with less than a subscription card.
pegasus30_1
I know rolfw :-(
Do U think it will take a long time or perhaps we have to change the titcard for something else. But this time it didn't function a long time with the titanium.
The how long question is a difficult one and if the answer is known, it isn't known by many.
samirius
I've got same problem, when i tried to reset card: program show unsuported titanium OS, no ATR on the card. When i send trap code nothing happend for 20 mins. I tried titanium prog: ver 1.6: 1.8; 1.9; 1.10 and same again. Is my card dead???? Please help
pegasus30_1
Rolfw,
Do U know if there is a prog that recovers the white tit cards? I've 2 whites they are burned
Yes I've had a play with it and will load it in the Utilities section, not 100% successful, but has achieved success.
peppey
my elvis in phoenix mode wont erase titanium card(sending trapcode)but somebodys infinity did.I think who let the dogs file is only for aston cams.
peppey
correction to above--my "elvis" phoenix mode and windows 2000,would not erase tit.card (1.10 prog.)somebodys infinity and windows xp did erase.
Norm
Aberdeen
Aberdeen, Scotland
I have just rewritten a titanium for C***x. When I inserted the card in the Infitity, it said "no ART and unsupported OS" exactly as mentioned in posts above. I carried on to erase the card using V1.10 and it all fell into place, erased the card no problem (although I find it is worthwhile flipping through some webpages during the erase cycle - seems to keep the PC awake!), downgraded to OS 1.03 as recommended and I burned it using the new files.
Gege - e possibile tradurre questo in italiano?
That's fine Norm, as long as there is an English translation alongside.
Norm
Aberdeen
Aberdeen, Scotland
Oops sorry - I was only asking if he could translate it into Italian! Otherwise we are seriously taxing my grasp of foreign languages.
I am doubly apologetic because I don't believe I've ever noticed the "post in English" banner at the top until this morning! Yellow card for me!
Norm.
