USB Funprogrammer
markd359
Hi guys,
Is it possible that someone can help me out.
Ive just installed my funprogrammer and it installed easily, then when i try to open it i get the message that its performed an illegal operation and all this data
FUNUSB caused an invalid page fault in
module FUNUSB.EXE at 017f:0041036b.
Registers:
EAX=00000000 CS=017f EIP=0041036b EFLGS=00010246
EBX=00000000 SS=0187 ESP=0087bca0 EBP=0087cd2c
ECX=00627e2c DS=0187 ESI=00000001 FS=0eef
EDX=00534242 ES=0187 EDI=010c07d0 GS=0000
Bytes at CS:EIP:
8a 08 40 3a cb 75 f9 2b c6 8b 35 94 7c 62 00 8d
Stack dump:
010c0430 00000000 00000000 00000000 00000000 00000000 952ae31d b493b94f c7f01ab5 4ed6e80e 5e4dee32 bf02aa15 cf03a771 1e7046fd ecf04e09 db9be30f
The red light is on and the programmer looks ready.
Any help would be greatly appreciated.
Thanks in advance.
Razor
Retired Mod
Ireland
It should be easy, maybe if you delete it and reload it, it might work.
caretaker
if you change the program to...infinity programmer you should be o k.
