USB ports
neilandrews1
skY
YORKSHIRE
Can I use a USB adapter to download software to the receiver if I do not have a serial port on my pc.
Cheers
Neil
Not as far as I know, you normally need some sort of loading program and can't run it on a USB stick.
tamazgha2003
dreambox 500s
tamazgha
yes you can
try google for
usb to rs232
neilandrews1
skY
YORKSHIRE
Does this definitely work ?
Cheers
Neil
gandalfthegrey
Specialised Contributor
Dreambox 800HD (clone)
Gibertini 85cm dish
4 way Diseqc switch........
linksys access point connected to Dreambox..
dublin,ireland
Hi neil....
I should be able to let you know the answer to this fairly soon....I have one ordered off e-bay. I recently got a new lappie with no serial port and cant update my comag sl55..hopefully this will do the job...let you know soon
cheers
gandalf
RFA
i dont know
saudi arabia
dose it work if i have usb to RS232 converter
any body tried it?
because my laptop dosn't contain serial port, and if it is work how can i set the program? i mean which port i have to set
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
Apparently some work, some don't. Depends on your PC and the adaptor. May also depend on your STB. Suck it and see. If you get a successful handshake, then try a flash.
At your own risk, of course ;)
Never used one myself.
RFA
i dont know
saudi arabia
ok i just bought on usb to serial, ok suppos it works.
but how about the port i mean when i operate the program it will ask to set the
port
BGonaSTICK
Brighton
As far as I can remember, the converter driver emulates a real com port, and uses the standard addressing, IRQ's etc. Your loader thinks it sees a genuine com port (which I suppose it does really...)
RFA
i dont know
saudi arabia
thanks god
after alot of searching and reading in this great forum I could upgrade my receiver, it is digitall world (SFT-5010).
I worked all last night to know how to set my COMS port, finally it works.
but i still need ur support because I'm still in the beginning (no experience), after upgrading my receiver I set it factory sitting then i install all hotbird channels TPS, Multivision and ABsat, unfortunately they are still not working. is there any keys or software need to be installed also in my receiver. please advice in detail.
thanks aolt for ur support
RFA
i dont know
saudi arabia
ya just I forgot
yes I bought USB to serial converter and it works
thanks
fay16
Startrack 2004 Super
For T*P*S and A*B channels, you have to change the AES keys every 10 to 20 mn.
fay16
I am also interseted to know how to use USB to serial converter.
Each time I want to upgrade my receiver I have to use the computer of my friend because my laptop doesnt have port com.
I have 1 USB/Serial cable adaptor.
So how to use it.
For info I have a startrack 2005 super.
I was using a null modem cable (RS232) to upgrade it.
1----1
2----3
3----2
mahmoud202
digetal world
egypt
please who can help me to update reciver digital world stf5010 please send me at my email address removed and all thanks for your kind
