Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Linux Based Receivers
Dreambox Support Forum
Dreambox Satellite Receiver | Tutorials | Software
Dreambox 800
v-box and DM800
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="smiffie" data-source="post: 595995" data-attributes="member: 286019"><p>Well PF100 is about as good as it gets, I have heard of Kontrakt before and I think its RG6 spec, it should have the spec stamped on it. </p><p></p><p>I have about a 30m run of RG6 down to a DM500 with one joint in the cable without a problem. Also a 20m run of CT100 to a DM800 via a VBox, I do get some interference on the 19E NME transponder caused by the VBox.</p><p></p><p>I get no power supply problems but I am only powering the twin LNB, the motor is 36v via the VBox</p></blockquote><p></p>
[QUOTE="smiffie, post: 595995, member: 286019"] Well PF100 is about as good as it gets, I have heard of Kontrakt before and I think its RG6 spec, it should have the spec stamped on it. I have about a 30m run of RG6 down to a DM500 with one joint in the cable without a problem. Also a 20m run of CT100 to a DM800 via a VBox, I do get some interference on the 19E NME transponder caused by the VBox. I get no power supply problems but I am only powering the twin LNB, the motor is 36v via the VBox [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
Dreambox 800
v-box and DM800
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
