hi,
please any one can help me how to programe a via cold card with a vx multi
because in the via code there is a hex file & bin file, so how can I inter the bin file
Thank you
You should normally have two hex files, one for the pic and one for the Eeprom. If you go to www.duwgati.com there is a step by step tutorial on most programming software.
hi rolfw
Thank you for this information, but there is a code in philsfiles for viaccess cold card with only one hex.
for programing with two hex is ok , but my only problem is there is only one hex wish is the pic but other is bin not a hex.
please help me.
hi,
Thank you
I have gold card + Echostar 3600IPVA rec. + programmer. Just download the viaccess zip files - PIC & EEPROM zip from usual sources, and write the card. Thats all. Good luck
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
