Viasat 1 22W Super Strength Atm
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
3726 L
DVB-S2
MPEG-4
1000-3/4
8PSK
Easily the strongest I've ever logged this channel..
Pushing 15db on the F15 at the moment..
rgds
VS
strong enough to be possible ..even on a 1.2m offset
pride21
Sandown Isle of Wight
i agree VS its 91% quality on my technomate its a pity that TV3 is not the same.
pride21
hi all new channel on this sat emmanual tv on 4141L 1925 at 55% quality
pride21
hi all found new channel called optima spoy on 3660R 6898 at 77% quality but no vidio or audio at the moment.
aceb
Prof Tuner 7301 /
Sussex
There was one of these on 17E till recently, I'll swap back to C on the 1.8m later this morning and take a look.
pride21
you should get it ok aceb with such a high reading,is it a hd channel with psk.
aceb
Prof Tuner 7301 /
Sussex
Something very odd on my kit with that signal, Crazyscan and EBS both refuse to lock anything, either on blindscan or by directly setting the parameters even though I can see the constellation on CS and it registers 10.8dB. Dream however locks it instantly but finds no channel when I scan it, very strange.
You might have seen my reply in one of the other threads but I discovered TV Verdade and Truth TV when I BS'd it last night. Signal is 8.4dB 3943L, 3200, 5/6 QPSK.
nelson_b
Contributor
similar odd results for me too --
the spiderbox sees it but will not lock ,
the F15 locks it at 10.7 db but will not download a channel.
regards --
pride21
hi aceb and nelson_b that 3660R is a strange one the first time i blind scanned i got optima spoy,yesterday i blind scanned again and now the receiver wont recognize it as a channel but a a data channel though it locks.
Lasseparabol
3 m Prodelin
C band 25K Chaparall Sidekick
Ku band SMW X-line lnb
Chapparal Corrotor 2 Wide band
Echostar AD-3000IP
Dr.HD F15
Sweden south part
Looks like Viasat1 is back 3726L 1000SR 3/4 8PSK.
10.0 dB strength and very low SR rate.
nelson_b
Contributor
thanks - Lasseparabol --
coming in at 8.2 db here on 1.8 offset + dr.hd.F15 (occasional picture freeze).
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Thanx from me also ..
solid lock 9.6 db here on Christina plus the new PLL lnb
rgds
VS
Kveys
Southern Finland
Also first time here Viasat1 and at once watchable picture:)
Retired human
Nope... Only getting 5.3db on that one. The only tp I lock on this satellite is the 4115 at 8.2dB
