VMA Stream Reader
New version: https://vma-broadcast.com/wp-content/uploads/2025/04/VMA Video Analyser Setup - 2026-01-02.zip
History:
2026-01-02
- VMA TS Recorder
- New tool for manual or automated TS recording of UDP TS. Can be automated via macro and
accepts the following command line arguments:
--nic
--ip
--port
--folder
--limit-time
--limit-size
--round-robin
--enable-start-timer
--enable-stop-timer
--start-at
--stop-at
--autostart
- Updated MacroEngine for
- VMA Macro Editor
- VMA Mosaic
- VMA Stream Reader
- VMA Transport Stream Analyser
- VMA Video Analyser
With the addition of the command line arguments and the macro language, it is possible to create complex scenarios. For example: VMA Stream Reader scans all programmed satellites for transponders and launches VMA TS Recorder to capture a sample TS of 100MB for each transponder.
I may have to improve some aspects, mainly the TS file name code, which only accepts automatic time stamped file names. This must be improved to accept user defined filenames, so that it is possible to automatically include satellite, frequency and polarity in the generated TS file name.
Other than this, it is working and offers a professional TS recording solution.
New version: https://vma-broadcast.com/wp-content/upl…02026-01-13.zip
History:
2026-01-13
- VMA Enigma2 Client Pro
- Added new Sat Finder mode - can be operated via web on mobile devices
Now you can go to the roof and use your mobile phone as a sat finder, connected to the Enigma2 receiver via the VMA Enigma2 Client Pro.
On the bottom of the page is a finger friendly channel list to switch channels.
The image (if signal is locked and service is FTA) is updated every second.
the enigma2 client pro include in the latest version works well on W7-64 !
the enigma client (not pro) zip file on site is erronous , zip send error : (vitor have a look on it)
You don't have to pay because you qualify for a free license.
@all: if you are a forum member for longer than 6 month with more than 50 posts, you qualify for a free license.
Is this 50 posts absolute?
I tried to be little bit more active (beside every day reading here), but no way i reach 50 posts in 1,8 remaining days to be eliglible for free licence. As a estonian i can compare myself to Kimi Räikkönen, who also spoke only then when he had something important to say. Or like that
Come on, only three to go!
New version: https://vma-broadcast.com/wp-content/uploads/2025/04/VMA Video Analyser Setup - 2026-02-06.zip
2026-02-06
- VMA Stream Reader Server
- Fixed a bug that prevented TS streaming in most cases
I have tried this version but encounter various problems:
1. tuning is unreliable. Perhaps because diseqc1.1 is not always sent, but the order I do things is: a. connect tuner, b. press the "v" next to sat. This gives me good strength and quality. Then pressing "direct tune" (12597V 450000) results in complete loss of signal (blindscan does not work either). In some cases, the mux locks with a good SNR. Crazyscan works as well
2. I configured a a satellite 15.0W and added "diseqc1.1 uncommitted" value 4. This seems to be accepted and sometimes works. However, when pressing the "v" next to "satellite" I often get the error popup "unknown diseqc step in grid: diseqc 1.1 4". Not sure what a diseqc step would even mean, but in the sat screen, it seems that the number "4" has been moved to the left column instead of the right one (where it is when it works). If I add the diseqc macro again then sometimes it remains correct for a while.
3. I do not really understand why there are 3 different types of diseqc1.1. So what is the difference between "diseqc1.1", "diseqc1.1 uncommitted" and "diseqc1.1 cascaded"? I found that only "diseqc11.1 uncommitted" works. The user guide does not explain it either. There is only 1 diseqc1.1 protocol. Cascading is just a matter of mixing diseqc protocols (in any order that corresponds to how the user connected things)
4. streaming does not seem to work out of the box. It produces an error like "[16:36:59.357] UDP setup failed: The requested address is not valid in its context 127.0.0.1:6969" (This error also occurred with the default port 1234 - firewall is off). After some trial and error I found this is due to some problem in the default configuration: on the settings screen "output NIC" needs to be set to "loopback" (which is not the default) or streaming will not work.
5. spectrum scan works, but clicking on the spectrum never leads to a lock: "] Blind-scan failed to find a carrier in that range window." I tried clicking as close as possible to th frequency 11043V. Direct tuning sometimes works (depending on the above problems)
6. At some point vma stream reader crashes: "unhandled exception has occurred... Arithmetic operation resulted in an overflow"
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.OverflowException: Arithmetic operation resulted in an overflow.
   at jZv:OkO^BCVffaEyuI%Abw{=.‬‭‎‬‭‏‏‍‭‏‌‏‪‪‍‍‭‬‍‭‭‬‎‮(Double )
   at jZv:OkO^BCVffaEyuI%Abw{=.‍‭‮‭‪‎‮‮‬‫‏‮‫‬‭‏‪‎‎‮‮(Object , EventArgs )
   at System.Windows.Forms.Timer.OnTick(EventArgs e)
   at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.7.3062.0 built by: NET472REL1
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
VMA Stream Reader
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/VMA%20Video%20Analyser/VMA%20Stream%20Reader.exe
Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.7.3062.0 built by: NET472REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
    Win32 Version: 4.7.3081.0 built by: NET472REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Windows.Forms.DataVisualization
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization/v4.0_4.0.0.0__31bf3856ad364e35/System.Windows.Forms.DataVisualization.dll
MacroEngine
    CodeBase: file:///C:/Program%20Files/VMA%20Video%20Analyser/MacroEngine.DLL
System.Speech
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
VMA.Remote
    CodeBase: file:///C:/Program%20Files/VMA%20Video%20Analyser/VMA.Remote.DLL
Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Data
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
This is on a 6904se card
You need to configure the software in the settings:
Select the NIC matching the IP.
Set the search range.
Etc.
Etc.
I understand that, but it would be better to set the defaults so that they work out of the box
One other buig (for this card): SNR is displayed as zero always
The software is just using streamreader.dll, so its capabilities are tied to what streamreader.dll provides.
You can exchange streamreader.dll on the fly in settings and a collection of available versions is included.
But I am not programming at driver level as you are under Linux! There is not much I can do in regards to missing/bad functionality.
My neither as windows is closed source. It works on linux.
I read some horrible, hopefully false, news, posted in this forum.
I refuse to believe it.
