Archive7
I am trying to edit several recordings on VU+ with BH 3.0.1 image using Cutlist Editor and then execute the cuts using MovieCut plugin.
The recordings are in *.ts with bitrate 1920 x 1080 so the problems might be related to the high bitrate.
I am not happy with the the Cutlist plugin. Once I press OK it puts a mark in the list but I can't find a way to delete the markings. And when I try to play the file it starts from this mark but wouldn't go back to zero position.
Also edited recordings seem to play fine at low speed X1, X2 but they hang when I go to higher speed. Also there is pixelization when I play it at high speed, when I manage to get it to cut as intended.
All in all this is not the best solution to edit movies and I have to keep the original because the edited one is not as good as the original. This defeats the purpose of doing the editing in order to save hard disk space.
Is there a better plugin than these two?
