The difference in temperature from single to double is that, twice as much heat to dissipate.
![roll on floor :-rofl2 :-rofl2](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
In one you have a single voltage regulator and the heat is distributed throughout the body / chassis of the tuner and the F connectors that the module has.
In the dual tuner, you have 2 regulators that generate twice as much heat and now you have only half of material to dissipate the same heat that you generate.
With an ambient temperature of 24'5°C the dual tuner chassis has 47°C (sensor attached to the tuner plate inside the receiver) when the 2 tuners are in use (important).
![DOH! :-doh :-doh](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
If you touch the fingers of the tuner's connectors, they have 33ºC+/-, for your hand this is hot with your fingertips at 25ºC+/- (measured now with a laser thermometer).
In general, the electronics have no problems below 50°C.
Personally I try to keep this temperature lower with extra fans.
Under the temperature of the tuner connector at 33 ° C to 30 ° C.
The internal chassis is at 43 ° C at this time.
Measurements made on the VU + DUO2 that has the same tuner as the Vu + Solo2 SE V2 (Twin tuner).
La diferencia de temperatura del simple al doble es esa, el doble de calor a disipar.
En uno tienes un solo regulador de tension y el calor se reparte en todo el cuerpo/chasis del sintonizador y los conectores F que tiene el modulo.
En el sintonizador doble, tienes 2 reguladores que generan el doble de calor y ahora tienes solo la mitad de material para disipar el mismo calor, que generas.
Con una temperatura ambiente de 24'5ºC el chasis del sintonizador doble tiene 47ºC (sensor pegado a la chapa del sintonizador por dentro del receptor) cuando esta en uso los 2 sintonizadores (importante).
Si tocas con la punta de los dedos los conectores del sintonizador, tienen 33ºC +/-, para tú mano esto es caliente al estar la punta de los dedos a 25ºC +/- (medido ahora con un termometro laser).
En general, la electronica no tiene problemas por debajo de 50ºC.
Personalmente intento mantener siempre mas baja esta temperatura con ventiladores extra.
Bajo la temperatura del conector del sintonizador a 33ºC hasta 30ºC.
El chasis interno esta a 43ºC en estos momentos.
Medidas realizadas en el VU+DUO2 que tiene el mismo sintonizador que el Vu+Solo2 SE V2 (sintonizador doble).
Diferencia viejo/nuevo sintonizador doble/Difference Old/New Dual Tuner.
Nueva foto donde mido las temperaturas/New photo where I measure the temperatures.
Los cables y conectores tambien disipan calor/Cables and connectors also dissipate heat.
PD:Sorry translations.
![Laugh Out Loud :-lol :-lol](/styles/default/xenforo/smilies/38389100.lol.gif)
