davidcmadrid
- Sep 21, 2012
- Age
- 48
- 40cm offset 19e, 1.5m 28e 1.2 M motor vu+
- Madrid Spain
davidcmadrid said:Is it possible to have a single tuner in A/B switch with A Fixed and B a Usals Positioner. When i select positioner in VIX 3.1.1 i seem to lose the switching possibility.
Hi,digi247 said:Yes it is although i dont use the Vix image personally i have a similar setup but again i dont have a USALS motor any more either but when i did al you have to do is in the tuner configuration menu set your fixed dish to Diseqc 1.0 and the rest of the satellites to Diseqc 1.2 now at the very end of the Diseqc 1.2 menu if you scroll down you can change the positioner number option to something which says Use USALS for this SAT which will allow you to enter your Lon and Lat details for all your other satellites.
I might add this is only tested by myself on the Uno with Blackhole image and Motor on Switch A and fixed on Switch B, Also why not treat yourself to one of the Dual tuner cards should be available from Friday this will eliminate the Diseqc switch.
Yes, you need to set up one LNB number for each actual LNB. LNB for the fixed dish is DiSEqC 1.0, and the other LNB for all the motorised satellites is DiSEqC 1.2.davidcmadrid said:In the end this was very simple I used disecq tones changing between AA and AB in tuner configuration i specified a second LNB for the fixed dish.
