Vu+ Uno network not working
Retired human
Hello,
Posted this on WOS forum but thought I'd put it here as well. This morning I woke up to find that the network on my Uno stopped working. I rebooted the box to no avail. I tried resetting the network settings, both DHCP and manual but the "Link" box has a red cross over it, as opposed to a green tick. The lights on the network port lights up when I put the network cable in and extinguishes when I take it out.
The image is OpenVIX 3.0 and I haven't changed anything in months on it. It just stopped working. I will replace the cable and see if that helps but in the meantime - any ideas?
CJ
P.S. It's a genuine box bought from WOS some years ago.
pgh13
Midlands UK
Have you tried restarting your other network hardware? Router/switch etc?
Try another port on the router - its not unknown for one to go bad.
Retired human
Three words: I hate HomePlugs.....
Sent from my HTC One X using Tapatalk 4
