Walrus1957 Scalar on Prime Focus Dish
Satcom1
1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver.
Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band.
Chicago
This Scalar Cone set was designed for small offset dish on C Band. It performs much better then commercial conical Scalar rings. I tried it on my Prime Focus C Band dish and gained 6 SQ over the flat Scalar ring that came with the LNBF.:cool:
patmos
STRONG SRT-4910+,SunRay4HDse,TBS5922, 2.4M P.F Apstar7(76.5 DEGE), 120cm dish PAS 10 Ku( 68.5 DEGE),3.0M Mesh Motorised dish on arc (AM44 (11DEGW) to AM33(96.5 DEGE),150 cm dish W3C(16 DeG E)+ side LNB Ew2A(10 DEGE),90cm W4/W7 (36 DEGE)
Mauritius
where did you get this?
Satcom1
Chicago
Very simple and inexpensive to make.
You can use aluminum roof flashing which costs about $10 USD for a large roll and has a nice springy nature and can be cut with scissors.
90mm ID X 260mm OD outer cone.
90mm ID X 200mm OD middle cone.
90mm ID X 140mm OD inner cone.
From the inner cone space the second and third cones 15mm apart on the slip sleeve.
Wrap the LNBF with a single layer of material 45mm deep to make a slip cylinder to attach the cones to. You can use super glue gel.
The LNBF will move closer to the dish with these cones peaked.
Satcom1
Chicago
Took these today, thought you might like to see them.:cool:
Picture 4 is used on a Primestar Elliptical Dish Model # 1.00M X 0.7M
See my Avitar.
patmos
Mauritius
Thank you Satcom 1. Nice work
God bless
antenna1
2.4M fixed and 1.0m Dish& Technomate receiver,
Can you give me some spec on making one for a offset dish please.
Look at post 3 - the dimensions are in there..
antenna1
I know that but in the 1st photo on post 3 you can see a bit cut out of the rings to make the conical shape but it does not say how much to cut out.
Satcom1
Chicago
How much to cut out? When you make a ring and form it into a cone on the lnbf throat, it will overlap. Just decide how much material you need to make a lap seam and cut the extra away.
Satcom1
Chicago
This cone Scalar works best on a 1-meter or smaller dish of offset design. Depending on the f/d of a 1.2 M dish a flat Scalar may work just as well. On an elliptical dish it will illuminate the smaller aperture only. But by trimming away the sides to form an elliptical horn the entire dish may be illuminated. On a 1m or smaller dish moving the cone Scalar in or out tunes specific TP's. This device makes the dish highly reactive and a signal of resonance (amplification) can occur making no signal jump to a high SQ. On some applications a fourth cone may benefit the overall gain. The last cone may benefit by being spaced at 7 mm away from the third cone.
nationsem
cw700
usa
To Satcom1, or any one that want to share knowledge
I am trying to make a cone scalar, but i have some questions.
1.-here i can only find ID, OD, and cylinder dimensions, but cone length's? Where i can find the the distance between the centers of both ends of each cone?
2.- i understand that the cones have a 1.5mm separation space, but all cones edges are at the same height? (if you take a look to the cone by one side, all cones edges are at the same heigth? or the inner cone it's at lower heigth? or higest heigth?
Thanks in advance
The best way would be to experiment yourself, as the o/p has already mentioned results depend entirely on the dish type and size.
Some heating/aircon duct and a pair of scissors.
