Want to buy a cam-card programmer
GURUJI
Dear Sir I want to buy a cam-card programmer.Can you please send me a site where I can buy this?
I thank you in advance.
mumtazrizvi
Pakistan
Hi Dear Guruji
Good Afternoon
I think CAS Interface II (with ADD ON) will do the job
as per your requirement. Correct me guys if I am wrong.
Regards
Mumtaz Rizvi :)
Mickha
North West
Hi GURUJI,
at the moment the Dragon Cam seems to be one of the best around, depending what's compatible with your receiver, but there are others. Getting the right programmer also depends on your computer, and set up, providing you have a dedicated Com port, on your computer or laptop, the Cas 2, with add on will do, equally so will the Infinity/Phoenix, but there is only 1 programmer that will program in Phoenix mode, using just the USB connection and that is the adteknik 3.6.
There are lots of sites to buy from, including:
_http://www.unapit.com/index.html
_http://www.goldwafers.com/shop/customer/home.php
e bay
and a load of other sites, if you do a search on google, for Dragon Cam, or any other satellite equipment, you should find a lot of sites.
Best wishes
Mickha
GURUJI
Dear Sir are there cheaper price programmers cause I don't want to spend much.ucas2 is about 70st,it's a bit expensive for me.
mumtazrizvi
Pakistan
Hi Dear Guruji
Good Afternoon
Don't go for cheaper Programmer because that will not fulfill the
requirement, because the Satellite Technology is going higher and
higher on daily basis. Spend once if you want to get success in
future also, its upto you choose what suits to you mate. 3/4 years
ago I bought the Multiprogrammer 2001 XL which is still going strong
so spend little more Guruji.
Regards
Mumtaz Rizvi :)
bakstreetcrawla
hi, i found this site cheap for programmers and helpful.
[url="http://*******************.com[/url]
Ideal_18
Farrukh
Star Track World-in-box II+CI
Pakistan
dear mumtaz rizvi
sir what do u thin about The Duolabs Dynamite USB Programmer is this one work fine and it might be a standerd one what i think so. but i think your opinion has more craditbily. :)
with regards
farrukh
