watching and listening to live footy
Sir Bronking
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
cheshire,algeria
i think i may have solved (in my case) watching foreign footy channels, and listening to english com (when possible)
ive been messing about with dvb-t (the card was in when i got computor) and in doing so tried a little experiment:
put radio 1 on "normal radio", and also picked it up through dvb-t using progdvb(would rather use another program but progdvb is the only one so far that works with my dvb-t card)
i think, because the program has to process the info i get a slight delay in sound :D
next tried watching dvb-s through different progdvb with sound down (only interested in picture quality (taq1 blade trinity) and dvb-t with sound up and hey presto both work fine.
next test, if i can watch city play weekend with dvb-s and get commentary with dvb-t the sync might not be to far away (fingers crossed)
btw, living in algeria cheshire is my signal coming from winter hill, as i don't think ive got every channel possible, (probably have to enlarge ini file i made with more transponders when i find them)
Oily
Satellite=Motorized Triax 88cm&a DM800HD with 500gb hd.Vu+ Duo
Radcliffe
I just listen to Century radio when Man United are playing:D
Sir Bronking
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
what? so when your watching utd on say tps foot and litening to century the 2 are in sync so u don't get to hear about the goal before you see it
btw the way if i was a formula 1 driver i don't think ide sign for a team called team oily (dosen't actually fill you with confidence:D )
Oily
Radcliffe
It's out slightly,but it doesn't bother me at all:)
As for my F1 team name,i'd think the same if i were the driverO-Ha
Sir Bronking
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
it does me, hence my experiment:D
Have added it for you, but does seem a lot to pay for the delay. :)
Sir Bronking
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
yes have seen it but for what it is seems pricey.
plus the fact i like to experiment/problem solve:D
hirdie
Visit site
dreambox,s 7020,800.gbox positioner,1.2 channel master dish
N east scotland
yes it is a bit expensive ,i was watching darts at xmas time on dsf and comentry on a 422 feed in english sound totaly out of sync i was waiting for phil the power to get a dart in the back of his head
Sir Bronking
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
hirdie,
did you know premiere darts is shown on dsf
tip: update your profile.....it helps when talking and offering advice.
RedDevil_UK
Retired Mod
Dreambox 7000S, VU+ Solo2, 1.1m Dish, Moteck SG-2100A DISEQC Motor
Rochdale
Hirdie
Bronking
hirdie, did you know premiere darts is shown on dsf
Should have gone to specsavers lol :D
Sir Bronking
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
different darts competition:-doh!
look at the dates:D
youve now got hyjacking my own thread:-bash
RedDevil_UK
Retired Mod
Rochdale
Doh!!! i thought darts was darts :-doh!
swiftly moving on.....
i have a 5.1 sound system plugged in my DVD player... if i was to plug that into my sky+ box and choose a Radio station, then put TPS on... i wonder how far the audio would be out???
Has anyone tried that?
hirdie
Visit site
N east scotland
no i didnt know it was on dsf i watched last matches at aberdeen on a feed but it went of just before phil taylors match
Sir Bronking
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
red u might have something there (i can do a similar thing)
if i used video sender from upstairs to tele downstairs and turn tele sound down, with sky digi box into dvd player 5.1suround sound and find it on say 5live i think it would work
u have try and i will next city forgein channel.
i also have on of them spare fta digi doxes i might dust that down and use it upstairs via comp if poss:rolleyes:
RedDevil_UK
Retired Mod
Rochdale
the other thing with it being sky+ if the audio is a little in front, i could rewind a notch :) or pause then quickly unpause.
sounds like a plan :) ill try it next game
RedDevil_UK
Retired Mod
Rochdale
OK, this mainly seems to be a challenge for me and Bronking :)
tried the trick above..
today, watching United vs W. Brom on TPS Foot
obviously french commentry... complete gibberish to the likes of me lol
anyway, i connected the 5.1 speaker system to the sky+ box, and chose Radio 5 Live channel 0105
great got to hear the English commentry while watching the pic from TPS..... wait but..... awww its out still
Saha scored and i knew before he kicked the bugger!!!!
The radio seems to be a good second in front Ummm back to the drawing board
PS
i tried the pause and unpause with sky+ to create a delay.... but it seems you cant use that feature on radio stations :(
the only way i see this being done, is if you dont mind being about 10 minutes behind real time
start a manual recording using sky+ and record the channel that has the commentry
and also record the TPS channels with Video/PVR/Dreambox etc
then start to watch and spend the first 5 minutes messing with the sync.
NO way is that ideal, but its the best i could do today.
redtez
80cm 0.2LNB motorised with DM500S
Warrington, Cheshire
I know some people can live with it, but I found the delay too frustrating.... you know.... the radio commentary tells you there's just been a goal but the Roonmeister has only just crossed the half-way line!
I've solved this easily by investing in a DAB digital radio with a pause/rewind function. I just pause live radio for a second or two, and hey presto, in sync!
Now, if only I could do the same with Chelski!!! :-ohmy
