archive10
Here's my Wave Frontier T-55 with (only) four LNBs.
I get 5W, 4.8E, 13E and 19.2E.
This is the "house" TV dish - e.g. the main thing was to provide two STBs with Viasat signal for the Danish channels (one dual tuner STB, one single).
The generic Viasat provided Telesystems PE57 was so bad with rain-fade when it really poured (and there's been a lot of that recently), that we decided to upgrade. As I saw an opportunity to colour match the dish to the house, and of course more interesting sat tech going in, I went for the dark-gray WF Toroidal 55. The 90 is nice, but the extra size not really needed for the four sats I wanted.
Main target was to expand our reception to include French, German and Italian channels (I don't speak arab, russian, polish etc) - so no big surprises in the choice of sats.
Dish went up over two days - these things require quite a bit of fiddling compared to single LNB offset dished. Biggest surprise was that normal LNBs tend not to fit under the primary reflector in the "centre" range, i.e. where the signal is strongest. Had to buy new Inverto Multiconnect LNBs to make sure the middle ones fit.
We now have higher signal strength and much better quality ("100%") on Viasat, and all the channels from France, Italy and Germany (plus a whole bunch of others too).
And of course it looks a whole lot better than the light grey Telesystems dish!
Major lessons learned include:
- All equipment much better priced via mail-order in Germany than anything sourced in DK.
- Web-calculator makes things much easier, but requires mount to be absolutely vertical.
- Sometimes when ordering things like mounts, they arrive in surprising colours and need to be spray-painted to match dish colour.
- You may need special "slim" LNBs just to fit them under the primary reflector of the T55.
- Wave Frontier Co. are really saving on washers, so when aligning your dish, you will scrape off a lot of the paint around nut fastenings.
- When ordering F-connectors, make sure you get the ones that has a 7-8 mm hexagonal thing, rather than a 2 mm one. Saves skin on finger-tips!
- When slipping on the slip-on-water-proofing-rubber-things that come with the LNB, they are so tight fitting on 8 mm cable that your hand/arm may accidentally slip and knock the dish out of alignment (ouf!).
