Weird Transponder
daaahhnuh
Vu+ Uno 4K SE
Dreambox 500
TBS-5925
Spaun SMS 5402 NF Multiswitch + Sky Zone 1 Minidish
Triax TD88 + Dark Motor using USALS
Suffolk
Just doing an occasional blind scan of 45W and stumbled upon this transponder (new since last scan) on 11549V. Seems to being using an encryption I haven't seen before. I would of just thought oh it must be satellite broadband, but there is video and audio streams! Any ideas?
BlindFaith
TBS 5925
..forget your analyzer. It's ACM continuos mode, not TS
Anonymous_1
Yes, this transponder (on air since a very long time) and much more around the clarck belt, in continuous ou packetized , are broadcast video. most of the time, this is a streaming video over broadband by satellite.
You can find them in C, KU and KA band.
Good luck.
Retired human
Is it possible to demodulate these streams to get useful data (video) out of it?
Anonymous_1
Example @ 62.5°E in KA band 20177 R 18750 ACM continuous (scan is 3 months old)
sometimes we are lucky
Maybe you can get a clean video with Sky TG24 @ 5°W (11449 H 1704 also available @ 33°E 11588 H 1704) ID: TX1 HUB, V: 256 A:272 by Elpitel, the channel is transmitted since 2013.
pontiend
Contibruter
south yorkshire
Admittedly I am not up to speed with these transponders.I do come across them sometimes.Is this one.
5West. 12556v 4104 8PSK 23.
TBS6925 100cm Dish.
Jamie A
I can get video from the signal at 33E is almost perfect, although the quality is awful.
I got some partial video from a continuous stream at 40.5W the other month (11154 V 22500). It was showing a film in English. Probably the only time I will get to see video from this satellite...
pontiend
Contibruter
south yorkshire
Correction.I have done it again.I am cracking up.
That last post of mine .12556V 4104 23.Is on 12.5West. not 5W.
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
Hi guys,
I hope it´s okay to let you know about this "GernericStream" List here satellitescommunity.de/gssatellites/0index.html (Please set www. in front).
A lot´s of findings there...
Best Regards
qwer.
