what do i do ?
alfa155btcc
I have a 85cm Faval Dish with 0.2 titanium lnb and alsat dark motor running off of a Technomate 1500 Ci Super
Bucks
I have just recently purchased a Technomate 1500 Ci super it came with a what was called a null cable to connect receiver to my pc, but u have just noticed there is problem i have socket on rear of pc tower that will fit it but there is only one and that is for the monitor, any advice would be most grateful
Saluti
alfa155btcc
:confused
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
The null-modem cable needs to plug onto a 9-pin D connector (RS232) not a 15-way of the same size.So it would't have fitted anyway.
Have you got any 9-pin D connectors on the PC?
If not, you may have a 25-pin male D connector on there,
in which case you'll need an adapter.
If there are no serial ports at all then a USB to RS232 adapter is needed,
or even better a serial port card.
