What does "Series Link" mean?
ceetee
SKY mini dish
Scarborough
Comes up on the Green button someimes instead of Favourites".
Carole
Carole
Hi Carole
If a Series Link shows up, you can use it to Record an entire Series of something, rather than just a single episode.
It means that the programme that you're watching is part of a series and if you set the link then you will either be prompted to watch the next episode or record it automatically for you - depending on what options are available and what you choose. It will also then perform the same action on all successive episodes.
There is a glitch which sometimes manifests itself on some receivers (my terrestrial box for instance!) where selecting the option to record a programme and the rest of the series will do just that but also every occasion that the programme is repeated during the week - i.e.the +1 channel and any transmissions on affiliated channels (5US, 5Life, More4, E4, etc and then their +1 duplicates) so I can easily end up with four copies of the same edition. Doesn't half fill the hard disc up quickly that way!
ceetee
SKY mini dish
Scarborough
Many thanks both for your replies,
Carole.
