Do you have a link to WEB SITE Rolfwrolfw said:Depends on the length of run from dish to receiver, but generally for under 25 metres CT100 or equivalent is the best to get. I use WF100 made by Webro, which is foam dialectric rather than air gap, but any of the equivalents are pretty much as good.
Make sure that it has both copper braid and foil, not the aluminium type as it is of inferior quality.,
Hi mkkid, Have a look here:- http://www.tlc-direct.co.uk/Main_Index/Cable_Index/Cable_PF/index.htmlmkkid said:Do you have a link to WEB SITE Rolfw
