Where can I change the keys in Strong SRT 4620II
berobacha
I have the digitall world SFT 190 PLUS
KSA
Hi, i got the Strong receiver, I got the new keys to open some hotbird channels, but i don't know where should i write it, the keys are from 16 letter, so where shall i enter it, please could anybody help me?
thanks,
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
Does it have a built-in cam slot?
berobacha
KSA
Actually i don't know what is built in cam slot, and i would like to know if u don't mind, but when i go to the menu, i can find somewhere written, slot#1....
hope u can help me,
thanks
jimbo
Retired Mod
Greater London
You really need to let us know some more about the receiver. Which model? Did you get a manual with it?
netemmye
strong 6130
80cm dish
ireland
rdi-sat.com or frocus.net
first you have to "patch" u r machine
nazhat
I HAVE STRONG 4620II RECEVER
IRAQ
I Have The Same Proplem My Q Isif Ican Chang The Keys Manually Help Me Please
azoz982000
just write 8282 in remote control , so the code window will apper and u can change it from that place....enjoy
d122k7trb
Judas Priest
IClass Receiver
2 Premium X LNBs Hotbird+ Nilesat
120" Dish
Computer system:
AMD Phenom Quad quad core 9750
4GB DDR2 Bus 800 RAM
MB: Asus Crosshair
1 TB Seagate Barracuda 32 MB cache
22" LCD Widescreen Samsung 226BW
SB X-Fi Xtreme
Armenia, ME: The Arab Countries
To view the channel you need 6969 code once or twice.
After using the 8282 mode and entering the codes, you'll be needed to use the following code 6969 once or twice to decripte the channel.
Arbi.
d122k7trb
Judas Priest
IClass Receiver
120" Dish
Computer system:
MB: Asus Crosshair
SB X-Fi Xtreme
you can find a series of master codes in flysat.com if you want.
Arbi
okeme
satellite
nigeria
hello i have a strong reciver 4653x i dont know if any body can help me with seca 2au solfwear patch
d122k7trb
Judas Priest
IClass Receiver
120" Dish
Computer system:
MB: Asus Crosshair
SB X-Fi Xtreme
you can either visit either rdi-sat.com or flysat.com
Arbi
