Where do I put the IRD and Boxkey in the Titanium?
jagost02
Single
Yamaha YZF-R1
North of the Tejo & South of the Thames
Regards,
Razor
Retired Mod
Ireland
There is no box key or IRD needed for tit card.
Just unzip your file and it will contain 2 files HEX + EEP ( some files have 3 HEX + EEP + CRYPT EEP ). On the top of Tit programmer V 1.10.0 you will see 3 boxes...marked load HEX.......load EEP. and load CRYPT EEP. that is all you need. Load the files and click BURN.
jagost02
Single
Yamaha YZF-R1
Thanx Razor,
I´ve done that. I am getting 30W well with the following exceptions:
-The MR freezes every so often but then starts again
-With the Titanium programmed as you say it will freeze and sit there eternally.
Any advice welcomed
Regards,
Equip:
Samsung CI-702E
Matrix Reloaded 1060 (1070 hangs worse than 1060)
Razor
Retired Mod
Ireland
I have heard that the Tit works best in MM. It will work in MR but some people have the same as you stopping and starting.
What OS are you using...103 105 106.... If you are brave try another OS on the Tit.
As for me ...I would leave it be and settle for what I have. But then I'm on Conax at 1w and mine works fine...No Stopping and Starting.
