which cable use receiver update via pc
porbandar
60 cm insat4b 93.5°E
90 cm Intelsat 10 at 68.5°E
porbandar,gujarat%2
i have micro-x mdr-4010 fta plus receiver but do't know how to update via pc , which cable use to conect pc ? serial port or usb cable ? help me.
Most receivers use a Null modem serial cable.
porbandar
porbandar,gujarat%2
thanks for informations but can i use usb means serial port to usb ?
HB13DISH
Retired Mod
Middle East - Israel
Not advised.
Use a PC with a serial interface and RS-232 plug. If not available at home, use a friend's PC or at work.
The O/S can also be imprtant.
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
I use a USB to serial adapter in conjunction with a null-modem cable all the time:), without a problem.
But a number of people have problems getting them working, it seems to be caused by wrong drivers/incompatible operating systems etc.
Often it is a matter of finding one that does work and sticking with it.
