To answer your first question Chaffey08, you will need a programmer, Elvis or similar, Multiprog software and the correct files, you can find a link for these in the Keys forum under Nobbly's Big Links list.
With regard to Canal+ on 19.2, much of it is in Seca II or Mediaguard II as it is also known, this is not yet hacked. Some of the channels are also available in other encryptions, you can find a list of which is in what on http://www.lyngsat.com/ look for 19,2E.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
