Zeus Muti-programmer....HELP!! :(
S
satwa
well got this great looking programmer
but it wont program my cards....
comes up with a "failed at address 1000" and the like
anyone had the same prob?
i heard these are a copy off a VP-20/DL-20
and they too had the same problem due to a
mistake on the PCB (a 10k resistor was put in where a link should be)
could this , if the same circit be the cause off my troubles?
thanks for reading
Satwa
M
markexon
Hi
I had that message appear with my Zeus programmer when I clicked on the 24C6X icon using the cardwriter software.
But it programmed the card perfectly after selecting 24C16.
what software are you using?
