3 West.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Was fine on my end, Only interesting point was Ant and Dec being told during the break someone broke into the compound.
Manikm909
Small'ish Dish Man
Kent, UK
ive been up ladder again, and managed 14.8db on that Italian MUX. i dont think i can get ANY MORE out of the old 1.2m
blind scan has found some feeds - which i wouldnt have got before on 3w thats for sure.
Sutton utd footy feed - FTA plus some enc
PS ended up swapping my Inverto PLL LNB for Inverto "IBU"
Just firing up old Bessie now on 3West - that footy feed Sutton v Mansfield is only a few miles away
** Forget that, wrong Sutton, my Sutton is the next town to Mansfield and not down sarf
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Im A Celeb is up, 8db again for me
Sutton Football is 7.8db for me on 11501 so you should get Im a celeb
Manikm909
Small'ish Dish Man
Kent, UK
do the people that operate these feeds, only give enough signal to reach the destination, i.e do they control it, or does it just depends on the size of their uplink equipment?
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
They absolutely control it, they will aim for a certain db rain fade margin based on the dish reception at the other end, no point pumping huge watts into it if no need. Their receive dishes are 3.8m to 6.3m for Ku depending which one they are using.
This satellite is also quite weak, so a very powerful uplink signal could effect other ones which they won't want to do.
Manikm909
Small'ish Dish Man
Kent, UK
6.0-6.3db for me again, i think it will flake out before it starts. Test card is solid at the mo tho
Footy feed 3.0W - 4:2:2, BISS.
I think they turn the wick down when the programme starts..
ITV feed is constantly breaking up for me tonight. Coventry vs Birmingham on 11008V 10000 and the UKR-028 feed are stronger.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Dropped down to 7.4db for me now
Manikm909
Small'ish Dish Man
Kent, UK
same as last night - feed broke up just before start - jokers... :)
Get that 1.5m Gibby on it, it will sort out them vanners and their tricks with the uplink signal level.
Manikm909
Small'ish Dish Man
Kent, UK
lol until the next feed that is out of reach of a 1.5m - does it ever end...gone from 88cm Triax, to 1m Gbby, to 1.2 Laminas to 1.2CM - and now...looking at 1.5m's - my garden is a decent size, but limited for sat sigs, unless wall mounted or placed in middle of garden path
I started off with one of them flat squarial dishes for SKY, stangely enough when I lived in Sutton just a few hundred yards from the footy ground that was on the 3.0W feed tonight.
It became a natural progression for me.
0.6m --> 1.2m --> 1.5m --> 1.8m --> 2.0m --> 2.2m --> 2.4m --> 2.8m.
The handy thing about a mobile platform is that it can be wheeled around easily, immobilised when in service, costs next to nowt to build and can be stashed away when not in use.
I built mine from a free pallet from the local builders yard, a set of 4 castors from eBay costing a fiver, some metal and bolts for the immobilising system costing around £20 and a bit of gravel board and decking off cuts to reinforce it.
3.0 W
EUFA Lipsync Test. BISS / 4:2:2 playback
I'm going to split these GTCombo posts into a new thread unless anyone objects?
Errrrrr, was just thinking about the BISS encryption hurdle for the SF8008 but didn't want to go into any greater depth
Google is yer pal.
Aye, crack on bonny lad, a topic in the receiver section would probably be appropriate?
