Just Sharing This My Channel Master 1.8 project.
Manikm909
Small'ish Dish Man
Kent, UK
lol i wondered that too but still cleaned it up.
just painted dish (with a roller @moonbase ) :)
not sure i'll bother with two coats, unsure
Looks OK.
If it is only for camoflague and you are happy with the single coat then no point making work.
Any slightly patchy sections will add to the camoflague effect :D
My paintwork is very patchy for that camouflage effect but the neighbours still moan.
Once it is up they can hear how good some of the music channels are from satellite reception.
(and if they complain then open your windows)
Manikm909
Small'ish Dish Man
Kent, UK
just finished sanding down / and painting dish - only have rear pic at mo.
had to take it inside, due to the moisture and frost...
looks almost brand new - sexy dish
here it is, after and before....
"Can you get Sky on that .......... ?"
Most of the sky, yes.
cokeaddict
Vu+ Ultimo4K, Uno4K SE, Uno4K, Solo4K, Zero4K, Duo2, SoloSE v1 & v2, Solo2, Ultimo, Uno, Duo, Motorised CM 1.2m dish, Hybrid Titanium Smart Lnb with CM feedhorn and a Zone2 minidish with Inverto Unicable II
53°E - 45°W
Just tell them it's your mini dish, the big one is coming soon
Manikm909
Small'ish Dish Man
Kent, UK
nearly there...
Manikm909
Small'ish Dish Man
Kent, UK
its been emotional.... :)
Manikm909
Small'ish Dish Man
Kent, UK
think im now ready for actuator \ dish \ and run the cabling.
will have to make do with a 12" actuator for now - waiting for other one to come into stock.
a pic of how it was
Manikm909
Small'ish Dish Man
Kent, UK
today was a good day!
dish up - @RimaNTSS arms installed - and first attempt at alignment.
due to never have setting up a CM1.8 before, and due to the amazing adjustment capablities, including the adjustsable LNB holder, i am finding it difficult to align - at least i found 1W- although, sadly, not as stong a signal as my 1.2 - i know the LNB isn't facing the sweetspot.
still lots of work to do on alignment.
The LNB appears to be pointing too high, even allowing for perspective (other visual illusions are available).
Looking good .....
This info / data measurements for lnb alignment is very useful - your measurements are in blue colour.
suedschwede
2.7m Laminas+Polarmount+JPC-Posi+SF8008
DE
@manikm909 Your LNB on the CM1.8 is way too steep, it has to go further down.
Manikm909
Small'ish Dish Man
Kent, UK
what i dont know is how HIGH i should raise the adjustable LNB holder? should it be at lowest limit \ highest...?
maybe i should fit the original arms and go from there, the reason i didnt is im missing the lower bracket thingy, and the previous owner had a c clamp to hold the lower arm on.
it might help to show me the the LNB angle at least
RimaNTSS
Some SAT-related hardware.
N-E from Riga
It can be at any position. You have length-adjustable feedarms, so by adjusting the length you can place LNB in any position. The main goal is to co-locate LNB's phase center with antenna's focal point. And that point is located 1830mm from the top point of the working area of the dish and 1080mm from the lowest point.
wium78
fixed,polar mount and C band dish.
south africa
Writing from South Africa where can one purchase that( fancy) LNB holder.My daughter is coming out to Africa next month and I would like her to bring me one.
