14w new Russian transponder
On the western European beam so no doubt in preparation for Russian TV channels to be kicked off all the satellites controlled by western European companies.
rodscha
It s labeled by Flysat as "new" channels...
I ll try them tomorrow,the beam is supposed to cover most of Europe.
so there must be a Russian bird on 14w ,which is near US's 15w...
so,who may be putting these channels for us to view?
Its Express AM-8. Russian controlled & owned.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
The three radio stations are active...........Alicante, España 1.2m dish.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
The 8 x TV channels now working and all FTA
mike1
Non-28.2° Sat Specialist
Yorkshire Television
Triax 64cm triax ( Darkmotor ) Inverto Black Ultra.
T55 - 28E/19E/13E/1.9E
Mutant AX 51 Open PLi
GT Media V7SX
Can anyone get these new Russian 14° West channels working on Engima 2 ?
Im using a Mutant 51 DVB2X.
I can scan in only the radio channels. Radio CH50-CH59. I can lock the transponder no probs strong signal with a 60cm triax dish.
New channels not working here on my multi-stream receivers shows a good signal but no tv here on 14°west o_O
I am posting my report from 14.0W @ Express-AM8 with the three T2-MI transponders activated
11544 V,14181,3/4,8PSK,PLP 0-RTRS,
11563 V,14585,3/4,8PSK,PLP 0-RTRS,
11646 V,14182,3/4,8PSK,PLP 0-RTRS.
mike1
GT Media V7SX
Hello can you export Astra.conf file for Engima 2? For Astra-sm
What receiver are you using ?
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
The T2-Mi reception at 14.0W is with the tbs6983 card and Crazyscan, 4T2 Content Analyser apps.
Hola..........GTMedia V8 UHD
Yes, the V8 here has found the three 14W transponders, nothing locked though on an 80 dish.
It is also running a conflict with some T2MI channels on 30 W, doesn't know which way to turn
Is there firmware later than 1.14 ?
Edit, it took ages to process the channels available, but they are now in the memory.20220227_094641[1].jpg
ESPN, though apparently encrypted is coming in.
SimonE
Gloucestershire, UK
23 Russian stations received here using the GT Media Combo. Thanks satesco.
Perhaps I didn't give it long enough before moving to another satellite then. Will try again this evening.
EnoSat
enosat.euweb.cz
Slovakia
-- RTRN 14W
f11544rtrs0 = make_t2mi_decap({
  name = "11544V T2-MI",
  input = "http://localhost:8001/1:0:1:6E:0:0:D84AD18:0:0:0:",
    plp = 0,
    pnr = 0,
    pid = 4096,
f11562rtrs0 = make_t2mi_decap({
  name = "11562V T2-MI",
  input = "http://localhost:8001/1:0:1:6E:0:0:D84AD2A:0:0:0:",
    plp = 0,
    pnr = 0,
    pid = 4096,
f11646rtrs0 = make_t2mi_decap({
  name = "11646V T2-MI",
  input = "http://localhost:8001/1:0:1:6E:0:0:D84AD7E:0:0:0:",
    plp = 0,
    pnr = 0,
    pid = 4096,
make_channel({
  name = "11544plp0", input = { "t2mi://f11544rtrs0", },
  output = { "http://0.0.0.0:9999/rtrs/11544plp0", },
make_channel({
  name = "11562plp0", input = { "t2mi://f11562rtrs0", },
  output = { "http://0.0.0.0:9999/rtrs/11562plp0", },
make_channel({
  name = "11646plp0", input = { "t2mi://f11646rtrs0", },
  output = { "http://0.0.0.0:9999/rtrs/11646plp0", },
