Manikm909
Small'ish Dish Man
- Channel Master 1.8M on Edision MIO 4K & GTMEDIA Combo, and CM1.2M on Octagon SF8008
- Kent, UK
not sure if the issue has always been there, tempted to try their first or second firmware, but the older ones are hard to get....links dont usually work.The Combo boxes seem to be a bit flakey since the latest firware update?
The 16E issue might be a data frequency that it has mistakenly locked as a video signal and you are scrolling past it in the list.
I have seen it before with other Android satellite Poop pourers where it displays the "app stopped working" message on screen then reboots the box.
You could test out a blind scan on a satellite with a lot of data frequencies, see how it copes?
![20220305_093446[1].webp 20220305_093446[1].webp](https://www.satellites.co.uk/data/attachments/127/x127114-25fc6de1f9ac2e5407e0b470672bcb76.jpg,qhash=SnfEHTd7qE.pagespeed.ic.7zohnlC37F.webp)
![20220305_095923[1].webp 20220305_095923[1].webp](https://www.satellites.co.uk/data/attachments/127/127116-9c92555d3da08e07829895189d6df403.jpg?hash=BTkr4rOgxG)
