Program for editing the Satellites.xml file
dreambox1959
46.3N-4.3E-FRANCE
france
a question about satellites.xml: I modified the contents of this file with notepad++ without problems for a long time, but recently if I inject a modified file into the sf8008, it works but does not take into account the TPs added??
in addition during the recovery by dreamset there is an error that I ended up finding and which came from this file !!
by downloading satxml on the net the sat 20E contains 16 TP but in manual search we only scan the first 8 ????
where can there be the number of TP per satellite?
Hugocz
VU+ ultimo 4k
CZECH REPUBLIC
I don't think that the satellite receiver still has the number of transponders for individual satellites stored somewhere. It probably gets this information from the Satellites.xml or lamedb files. Send me the "defective" satellites.xml file to hugocz@jevicko.org and I will look at it.
dreambox1959
46.3N-4.3E-FRANCE
france
satellites.xml is at the same time in ETC/tuxbox and in etc/enigma2!!
dreamset only sends to one directory, and when dreamset reads, it crashes when it sorts the data!
in manual research (openatv and openvix) he chose the sat.xml of etc/enigma2 and I modified that of etc/tuxbox!!!!
EnoSat
enosat.euweb.cz
Slovakia
satellites.xml:
/etc/tuxbox - this file is maintained by the image team
/etc/enigma2 - this file is managed by the user
the user file always takes precedence over the team file (if e2 detects an XML file in /etc/enigma2, the XML file in /etc/tuxbox is ignored)
dreambox1959
46.3N-4.3E-FRANCE
france
ok thanks
EnoSat
enosat.euweb.cz
Slovakia
or remove satellites.xml from /etc/enigma2
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
Delete both xmls from both locations in the receiver. Then you send the xml that you previously edited back to the receiver, then there should be no problems. That's how I did it years ago when I was working on the settings lists for E1 and E2.
Hugocz
VU+ ultimo 4k
CZECH REPUBLIC
I have finished the new version 1.1.8 of SatXmlEditor. The main novelties are the ability to select multiple items in the transponder table and the ability to copy / paste transponders via the windows clipboard. The description is here.
i have dm 800 tp 11278v block scan it going on full transponder i add notepad aa+
to be delete it still block scan
EnoSat
enosat.euweb.cz
Slovakia
what does your file look like ?
do you use the tuxbox or enigma2 directory ? (post #25)
Hugocz
VU+ ultimo 4k
CZECH REPUBLIC
Can someone send me the cables.xml and terrestrial.xml files to hugocz@jevicko.org? Thanks.
Hugocz
VU+ ultimo 4k
CZECH REPUBLIC
The number of downloads of the program is close to 100. Does anyone have any comments on the latest version? I'm not that good of a programmer. :-)
I think it's one of the nicest looking UIs there for transponder editing. It's very clean, straight-forward and, so far, stable. I need to spend some more time with it but it's certainly going in the right direction.
7mdish
Milan, Italy
Totally agree. Very good job.
Hugocz
VU+ ultimo 4k
CZECH REPUBLIC
Thank you for the compliment.
What am I doing wrong? Satellites.xml file definitely exists in the given path...
EDIT: Ignore this - my fault there.
One bug I am seeing is if I press DEL button to delete a satellite (instead of F8), I get "Delete record?".. followed by:
I suspect the DEL button is not meant to be used but it still asks for a record to be deleted. F8 works OK.
Hugocz
VU+ ultimo 4k
CZECH REPUBLIC
Yes. The Delete key (and the Insert key) will run a standard windows procedure that bypasses my implementation. I will fix it in the next version.
The question is whether to leave both keys functional, or cancel the F8 (F9) keys and replace them with the standard Del (Ins) keys.
