60e Intelsat 904
keith100
Penta 85, Digipower SG-2100a motor, Icrecrypt S3200CCIHD, TBS5925, 13e to 66e
Aberdeen
I was getting Kuban TV on 11490 V 5788 earlier this evening but gone by the time I got to write this.
Not the best of signals, only 50% or there abouts.
I've had this occasionally before but it never stays long...
Archived-1
Persona non grata
uk
Thank you for the information, I did lock a feed from this bird a few years ago, and I do keep having a go for it, only yesterday TBH no luck :(, I will make a note of the tp and have a go for it :)
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Tried but not a whiff with a 1.5. Foot print way off from here.
adonis1
7.9 db with F15.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Yes I guess being more East has a much better chance of receiving that Bird.
keith100
Aberdeen
adonis,
Out of curiosity, do you get any of the other transponders on the same beam (Spot 1 Wide) as Kuban TV ?
I was getting Rostov-Papa on 11072 V 2170 last winter, which was a much stronger signal than Kuban TV, but that transponder is now gone.
flysat's reception map misses both Aberdeen and Syros and satbeams' one catches Aberdeen with a 100cm dish and misses Syros completely.
Here's a scan I just made.
Note the peak at 11491 V of Kuban 24, but no lock because it went off air for the night just before blindscan!
Nika TV is only slightly weaker than Kuban 24.
But IS-904 signals are erratic, they may be easy (or hard) for weeks with no apparent reason.
11567 V 10000 is a new frequency for RuSat package, before it was on 11159 V that never locked.
The Rikor packages at 11635 V and 11675 V are FTA for several weeks already. :)
adonis1
Well I receive the most transponders of is904 (Spot 1 Wide) some with stable reception , some others not.
I also receive FTA Ricor package freq. 11635 V and 11675 V.
But Ricor package will cease all his transmitions by the end of this month , that's why still remains FTA.
(google translation)
http://smarttv.rikor.com/
keith100
Aberdeen
Nothing at all for me tonight, I will wait a few more weeks for the trees to drop their leaves and see what signal I get then.
Good signals this evening, probably haven't seen TV 100 since last winter.
10973 V 3330 3/4, 5.7 dB: TV 100
11491 V 5786 3/4, 5.7 dB: Kuban 24
11513 V 2616 3/4, 6.7 dB: Nika TV
Archived-1
Persona non grata
uk
Getting a slight sniff here, Kuban 24 11490 V 5788 well under lock but room for improvement weather wise, I will keep an eye on it when conditions improve.
Retired human
That's an interesting satellite for you there. This is one footprint that favours the north rather than south!
Retired human
Nope - I just want to get as many channels/satellites as I can! That sat was interesting to me because it carried Russian packages but that's all gone now...
Archived-1
Persona non grata
uk
We all know you will have a 1.8 Alex :), it just a matter of time :) your just like me and cant wait to get your hands on one, when I get mine all set up I will set my slingbox up so you can have a play, it might move you on a little quicker :D.
Archived-1
Persona non grata
uk
Also getting a sniff at 11512 V 2617 Nika tv tonight, but under lock :(, i will try tweaking the LNB tomorrow
Archived-1
Persona non grata
uk
Getting a little bit better signal here tonight but under lock, I am getting nothing on 11512 V 2617 Nika tv
humaxboy1
Gibertini 125 cm 75°E-45°W
ClarkTech Diseqc HH390 Prolong arm
Inverto Black (white) Ultra Single LNB
Octagon SF 4008
Slovenia
Nika moved from 11512 V to 11516 V some time ago and the trp has also 11519 V DVB-S2/QPSK ACM 729 3/4. Because of that the power was reduce drastically and hardly lockable on my side with 120 cm. Kuban 24 is a little bit stronger....
Humaxboy
Archived-1
Persona non grata
uk
Wow locking Kuban 11490 V 5788 now, weak but locked :), please ignore my sat position.
Retired human
