TBS 6925 PCi Card with hardware blind scan in DVB-S2 and DVB-S
remlap
Wales
I know even BBC News is struggling to keep reception of their feed on 23.5E I've seen them lose it.
BlindFaith
TBS 5925
I guess they have a bigger dish ;)
remlap
Wales
mephisto
TBS 5925 DVB-S2 TV Tuner USB
Dreambox 500S
Vantage X221S CICX
Samsung DSR 9500 VIACI
Echostar AD 3000 IP
1,2m offset dish w/polarmount
Inverto Black Ultra lnb 0.2 db
Actuator Superjack 12"
55°E - 30°W
Uzice, Serbia
BBC Proms 2014
Eutelsat W3A (7E) - 11070 Vertical 7200 16APSK 3/4 DVB-S2 4:2:2 MPEG-4
Archive-8
Having trouble scanning nilesat 7w with the card now.
The card will not pick up 10719 V 22000, yet 3 of my sat boxes pick it up.
Any ideas please?
mephisto
Dreambox 500S
Vantage X221S CICX
Echostar AD 3000 IP
55°E - 30°W
Uzice, Serbia
Two hits in a row!
Astra 3B (23.5E)
11658 Vertical 2333 16APSK 5/6 DVB-S2 MPEG-4
11662 Vertical 4666 16APSK 5/6 DVB-S2 MPEG-4
mephisto
Dreambox 500S
Vantage X221S CICX
Echostar AD 3000 IP
55°E - 30°W
Uzice, Serbia
Astra 3B (23.5E) - 12736 Vertical 7200 16APSK 3/4 DVB-S2 4:2:2 MPEG-4
mephisto
Dreambox 500S
Vantage X221S CICX
Echostar AD 3000 IP
55°E - 30°W
Uzice, Serbia
Belgian cup: Kortrijk - Leuven
Astra 3B (23.5E) - 11662 Vertical 4667 16APSK 5/6 DVB-S2
remlap
Wales
EBU has begun using NS3 on 10E with rumoured settings of 11075 V 68571 3/4 16APSK.
Rumoured to be bunch of transatlantic sports feeds.
Carrier is huge!
BlindFaith
TBS 5925
NS3 -> DVB-S3 by NewTec ?
@remlap, what is the source of your information? Apparently the TBS cards don't lock :(
Should be a 72MHz wide transponder
remlap
Wales
Bit of Googling and found a forum I can't mention here sadly.
Digital Video Broadcasting by Satellite - Third Generation (DVB-S3) will be the future standard used in Europe for the transmission of digital television , as the successor of standardized DVB-S2 .
http://ca.wikipedia.org/wiki/DVB-S3
Just when I thought H265 was going to be the next broadcast standard along comes DVB-S3
BlindFaith
TBS 5925
remlap
Wales
Think the latest generation of coming TBS cards can do the high symbol rate in use but the NS3 standard is propitiatory so yeah expensive gear.
remlap
Wales
So the tbs6925 can't decode dvb3
It's not DVB-S3 its NS3 a different standard, DVB-S3 has not been defined.
6925 can't anyway due to the high SR but the 6983 can handle the SR but not the standard.
aceb
Prof Tuner 7301 /
Sussex
pontiend
Contibruter
south yorkshire
Often on first boot I get Error code one .Windows dose not find the TBS 6925 Driver.
I have read somewhere that some ASUS motherboards have a problem with this.
My board is ASUS, but not that one.
A reboot normaly sorts it.But is a nuisance.
Is there a way to start the card from within W7.
far78
1m Orbital and Supreme Intelligent Dark Motor, TBS 6925 and Tevii S464 PC cards, TM5402 M1
York, North Yorkshire
I've had this a lot with my recently acquired TBS 6925. TBS themselves say it's potentially a faulty card but I've read a few reports about this so am not 100% convinced its a hardware issue, more software.
What helped me was uninstalling the TBS IP app - I had no need for it so have removed it and my problems have gone away, no idea if this will help you though.
