TBS 6925 PCi Card with hardware blind scan in DVB-S2 and DVB-S
mephisto
TBS 5925 DVB-S2 TV Tuner USB
Dreambox 500S
Vantage X221S CICX
Samsung DSR 9500 VIACI
Echostar AD 3000 IP
1,2m offset dish w/polarmount
Inverto Black Ultra lnb 0.2 db
Actuator Superjack 12"
55°E - 30°W
Uzice, Serbia
Bundesliga (w): Frankfurt - Wolfsburg
Astra 3B (23.5E) - 12720 Vertical 9600 16APSK 3/4 DVB-S2 4:2:2 MPEG-4
Archive-8
Has any one else noticed that these cards are not as sensitive as it first was.
I find my sat boxes beat the card, and that the card always used to beat my boxes.
Mine didn't show any sensitivity degradation for three years - until it went belly-up with an intermittent LNB voltage fault.
Now use a 5925, the USB version. No problems, and more versatile (PC, Laptop).
Archive-8
Well that's £200 down the drain then.
Tried a repair, but difficult with it in-circuit to locate the problem. Took leads out from the card, connected to the LNB circuit to check the sequence of events from card power-up to fault appearance, but it really needed extra circuit connections for a more thorough check. At which stage, patience failed me.
Way out of guarantee, so as you say, my loss.
Archive-8
Just found the PayPal invoice. 29/04/2014 for £179.00 to red apple digital. So if I can find the box, I might be lucky.
aceb
Prof Tuner 7301 /
Sussex
According to a report on Ricks the 6925 is now out of production, I've just checked and the TBS online shop is showing it out of stock.
cristan200
hotbird
usa
ho has tbs ip data 3.0.4.0 card 6925 or 5925 ?
please take in here for me setup tbs ip data 3.0.4.0
i need it
Jamie A
Seen on 12.5W (ignore the satellite position in CS), BBC news feed in 16APSK. First one I've noted using this modulation.
remlap
Wales
Noted from the BBC (I have seen one or two) or 16APSK totally?
Jamie A
First BBC one I've received myself. I did see your report of a 16APSK BBC feed on 23.5E. I suppose it's only a matter of time until broadcasters adopt this modulation permanently.
I use EBS Pro with my TBS6925 card and keep missing some frequencies that a receiver always picks up. I asked the EBS Pro support if there was a fix and they advised me to set EBS Pro to use BL2 mode (blind scan 2). However, when I try this I get an error message saying my TBS6925 card does not support BL2 mode.
Is there any type of software update to get a TBS6925 card to support BL2 mode?
Thx
CrazyCat
crazycat69.narod.ru
13E 4.8E 4W: Dish Variant CA-902 0.95m + 3xLNB Ku-Universal DreamSat DS8 + DiseqC 1.0
30W-95E: Dish Strong 0.95m + LNB Ku-Universal ALPS BSTE8-751B + Motor PowerTech DG240
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
TBS 6925 & 5925 not support BLScan2.
Laser
Getting a TBS 6983. Due this week.
At a guess I presume the 5West Mulitstreams OK and 12.5West?
Can you blindscan for feeds.. If so which is the best satellite?
Thank you
