Amos 7 (was Asiasat 8) 4W
Archive-8
My dish is well out, bodged a signal out of it at the moment.
Will go and tweek it properly in the next few days.
But the general signal levels seem very low, compared to @william-1 last screen shot.
The dr hd is showing 6.0db on 10722
MCelliotG
Thessaloniki, Greece
TVH after the change I can only receive it when I tune my antenna to 3W and there it comes with 9.5db only. Looks like it gets lots of interference from 5W, I wonder why the resorted to such a shitty frequency plan...
ZIK had the same problem as well.
11258V is absent on me today, while 11342 continues as is. Was there any change?
11630v left Knesset Channel
left
11636v left TBN
11258v left yes
popovp
My system:Receiver-Ferguson Ariva 102E HD, Sky Sat 9900FTA+emu;Ferguson FX-6600CR/OCTAGON SF318 soft;LNB-Sky Sat, universal, 0,2dB;1.17x1.06m offset dish ;Diseqc 1,2 +USALS Moteck2100A motor; 1,2m parabola+0,3dB Inverto @ H-H Strong SRT DM 2100
Varna, Bulgaria
11258V, 11635V, 11647V, 11658V back again
The 5 west Data Stream on 11591 H DVB-S2/8PSK 30000 3/4 wipes out Amos-3 transmission TVH on 11590 H DVB-S/MPEG-2 3700 3/4 in my location as I can get 5 west on a region-1 45cm mini dish here,
I agree with some of the previous comments this is a poor selection for a frequency sharing plan between 4 west & 5 west,
11633 H 30000 MXF feed from 5 west is 95% signal quality maybe they will put TVH here next :-rofl2
Looking at this link again in post #111 shows that most of the frequencies used by Amos-2 can be duplicated by Amos-3,
Frequencies 10722H,10759H & 10805H do not exhibit the fade that they used to maybe they have moved to Amos-3?
I used to loose these transmissions when it rained it is raining here now & the signals are rock steady.
Amos-2 10842 H 30000 has gone here now but the channels are duplicated on Amos-7 12315 H 15000 although the signals are low on 10722 H 27500 & 12315 H 15000 the picture is OK with no signs of breaking up during a heavy rain storm here.:)
Signals received here during a rain storm.
10860h got 8.2db with 4.5m
pontiend
Contibruter
south yorkshire
I only get one transponder at 4 West just now.
11567H 14998 8PSK 2/3.
However just for fun I did a Crazyscan of 4 West and came up with this.I don't know if it belongs there.
TBS6983 100cm Dish.
VodzigorLans
Setup is down atm
RU, Saint Petersburg
Yeah, i can see it too so it is Europe beam of whatever sat it is...
I am beginning to think that only 2 transponders remain on Amos 2 10841 H 30000 & 11507 H 15000 as these were not picked up this morning when Amos-2 was off the arc this morning but have returned now Amos 2 is back on the arc.
Can someone please check the TLE data to confirm this.
AMOS 2
NORAD ID:
28132
LOCAL TIME:
17:39:40
UTC:
17:39:40
LATITUDE:
-0.22
LONGITUDE:
-3.98
ALTITUDE [km]:
35784.94
ALTITUDE [mi]:
22235.73
SPEED [km/s]:
3.07
SPEED [mi/s]:
1.91
AZIMUTH: 185.2 S
ELEVATION:
+30.4
RIGHT ASCENSION:
04h 27m 40s
DECLINATION:
-08° 42' 45''
Local Sidereal Time:
04h 46m 40s
The satellite is in day light
SATELLITE PERIOD:
1437m
TVH has left Amos-2 & moved to Amos-3 11590 H 3700 no signals here now on what is probably a Central European Beam & not a Wide European Beam as some map suggests,
Above is the real Amos-3 European Beam.
I don't think 11590 H moved on Amos 3 because it's too big difference of signal during a day/night, even by 3 dB,even if would be on the CEE beam,and ironically, just on the area where should be the strongest,namely DTH signal.In two hours the signal has dropped 0.7 dB.So Amos has a serious problem...
11373 H,5450,4/5,Dvb-S2/16APSK-Hun Feed
pontiend
Contibruter
south yorkshire
After a bit of fiddling with the longitude I get these transponders now.
TBS 6983 100cm Dish.
The first feeds on Amos 7:
12406 H,3200,3/4,Dvb-S/QPSK-ROU-Tele-M,
12410 H,3200,3/4,Dvb-S/QPSK-R2*TV
AMOS 2 This morning 09:45 GMT
NORAD ID:
28132
LOCAL TIME:
09:40:06
UTC:
09:40:06
LATITUDE:
-0.31
LONGITUDE:
-4.05
Signals down again on 10842 H 30000 & 10908 H 15000 all other transponders OK re post #151 so in my opinion it looks like these are the only transponder left on Amos-2 that I can receive here.
VodzigorLans
Setup is down atm
This ones are at CEE beam for sure, first ones unlocked for me only seen through blindscan2 no locked option...
Kypros_Pambou
TBS:6985,6925,5925usb
5 Pace&Arris IPTV Gateways
Greek Cyprus
Receptions with 2.1m
Some older transponders used for feeds(CTV provider)on Amos 3:
11386 H,2400,3/4,8PSK-CZE 039,
11389 H,2400,3/4,8PSK-CZE 023,
11392 H,2400,3/4,8PSK-CZE 036,
11395 H,2400,3/4,8PSK -CZE 040,
and a new one in mode 16APSK:11613 H,5450,4/5_MTVA SNG HUN:
popovp
Varna, Bulgaria
