Advice Needed Best 4K receiver
On one of the receivers change 26E (or whatever satellite you are testing on) to No Motor. That way the dish won't move when you swap the cable over.
4Himdj
1.2 Laminas Dish
Rome
hello I've a problem with 4k receiver too
I have ax hd61. when I watch football the picture change brightness continuosly. this problem seems to disappear on my 4k tv if I choose HDR10 video output on the receiver. but I send trasmission on other television in my house through hdmi modulator. when I do this I have same issues on the other televisions: I need to reset on SDR video output (but the problem now appear on the 4k's one)
any guess?
thank you
any guess?
thank you
Please start another thread next time you need to post, preferably in the correct section.
The easy solution would be to get a cheap second receiver to feed the HDMI modulator.
I've seen HD Fury products that downscale and convert HDR-to-SDR but it would be cheaper and more flexible to use a second receiver.
Gladstones
Zone 2 Fixed @ Astra 2
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Just done some test on both receivers
On badr4@26e
12073H27500
Octagon not able to lock
Xcruiser locked at 80% no picture scratch
12683V27500
octagon locked at 33% with some picture scratch
Xcruiser locked at 63% no picture scratch
Both time done test at same dish position
Then also tried to maximise the signal
Result remains the same
Blind scan
Octagon 114 channels
Xcruiser 141 channels
On badr4@26e
12073H27500
12683V27500
Blind scan
"No picture scratch" = solid/perfect video?
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
I meant
Picture scratch = pixelated
No picture scratch = solid /perfect
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
On badr4@26e
12073H27500
Xcruiser locked at 80% (Not even pixelated)
12683V27500
octagon locked at 33% (some pixelating)
Xcruiser locked at 63% solid /perfect
Blind scan
stephan94
Bavaria
when i see the Xcruiser menu images i see it is exactly the same as the 2014 OpenBox Sx6.
Manikm909
Small'ish Dish Man
Kent, UK
ha @ozumo - i was about to say the same.
StiH239 (Newport) processor
Manikm909
Small'ish Dish Man
Kent, UK
On badr4@26e
12073H27500
12683V27500
Blind scan
On my Octagon SF8008 \ CM 1.2m
12073 - H - 27500 = BBC World News - MIddle East (9.2db for me)
12683 - V 27500 = Al Aoula Inter HD (10.5db for me)
On my Icecrypt 6600 \ CM 1.2m
12073 - H - 27500 = BBC World News - MIddle East (49% for me)
12683 - V 27500 = Al Aoula Inter HD (89% for me)
the slightest nudge picture goes on BBC World News on both STBS, but Al Aoula Inter - solid on both - but down to 6db
Out of curiosity (only!): the main UK seller of Icecrypt kit went out of business a few years ago, but does that brand still exist as "viable entity"?
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Assuming you are using an Inverto Black Ultra single, how are the receivers connected, is the Octagon connected to a loop through from the XCruiser or are you swapping the cables over? If you are swapping the cable over that's a decent improvement.
Are you using just one receiver to nudge or on each receiver separately? One receiver's nudge may be bigger than the other's. Do you receive any extra channels on 26E? Also where can you buy this receiver?
How about 23.5E 12642V 280 Radio Osttirol
still no signal 12642v280
also tried 12642v555 nothing
How about 10493H 1500 on 26E? I don't expect anything with an IBU but will be interesting to know if you can input such a frequency :)
Manikm909
Small'ish Dish Man
Kent, UK
ill try these too in a mo
I doubt it very much, the tuner frequency span will be determined by the firmware governing the tuner and demodulator chipset
Broadcom have experimented with capturing frequencies outside the norm with a wideband chipset algorithm, but I believe it is more cable oriented.
Manikm909
Small'ish Dish Man
Kent, UK
